Frankenstein project | Ford Explorer Forums
Henderson, Kentucky
1993 Ford Explorer
Is there somewhere on here to find good wiring schematics for a 1993 & 1999 Explorer XLT in reference to everything between the driver's door & driver's seat? Removing the door panels, carpeting & seats from a 1999 XLT Limited & Placing them in a 1993 XLT. Problem? Is all switching for memory settings for the driver's seat located in the seat, or the door? What wiring will I need to add to the 93 to make this work? Also looking into placing the 99 headliner into the 93. I think with a little wiring & relocation of the existing dome light, it will work.:feedback:
I got the carpet all changed out tonight & all of the seats including the two front power seats. Everything went pretty smooth until I got to the driver's seat. The passenger seat had 1 hot wire & 1 negative wire. the driver's seat has 1 hot wire, 1 negative wire & 9 wires that connect to ????? how do I get this seat to move? Simply applying power does not do the trick.
