From iceland | Ford Explorer Forums - Serious Explorations
From iceland
gunnarja
Hvammstangi ICELAND
Hi - I live in Iceland and is owner of Ford Explorer 4WD 1999 (also owner of Ford Fairmont ´79). The Explorer is in dayli use.
But can anyone tell how much I should thigten front hub assembly, have found on the net from 184 lbs to 250 lbs ?
:exp:
..........and this Ford is in the volunteer Rescue team that I am member of.
i had a 91 and i would jack up one side at a time and tighten them that way i was sure they were seated but if im right there is a notch on the plate and its easy to miss but that would be a guide
Welcome! Awesome stable of vehicles! :thumbsup:
The front axle nut torque spec is 157-213 ft lbs...
