94Sport5Sp
- May 11, 2005
- River Hills
- 94 Sport
Hi:
I am having a problem on my 94 explorer. The steering seems to resist changing direction and then pops to the direction I want. Very annoying when traveling down the road.
While looking under the front I had someone turn the steering wheel right and left and I could see the front axles moving with each change in steering. It behaved like being in 4wd and then doing a tight turn the u-joint would pop.
I raised the front wheels off the ground and verified that the hubs were free (I have manual hubs) and I verified that the hubs would engage and dis-engage when set. All seemed fine but when the steering was turned the u-joint would pop. I decided to lock the hubs and to rotate the tires by hand. Worked well until I swivelled the wheel for a turn. Even the slightest swivel would cause the drivers tire to not rotate. It seems that the u-joint is frozen and will not give causing the wheel to not rotate. Passenger is stiff but I can rotate the tire with all degrees of swivel.
Does this sound like the u-joint? How much work to pull out the axel? I am assuming that the hub and rotor all have to come off. If I do this is the axel supposed to slide out of the differential?
Thanks for your comments
