EasyRhino
- March 25, 2001
- Kailua, Hawai'i
- '02 Limited 4.6L 4x4
100K miles on my 2002 Limited AWD 4.6 V8, had the tires off today for cleaning and inspection, noted that both front top ball joint rubber boots are torn.
I suppose that this means that the ball joints themselves will require replacment more sooner than later.
How hard of a job is this? The ball joints do not appear to be a bolt-in to the top control arm.
Last, at 100K miles, should I just go through the front suspension 100%. I did both front wheel bearings about 25K miles ago, so those are good. If doing the entire front suspension, what parts should I have in hand besides the top ball joints and the shocks? I thinking add to that the tie rod ends.
Anything else?
Anything else?
