alpine41
- March 11, 2002
- Newcastle, WA
- '91EB
Left front brakes gets hot to the point of smoking after driving 20 miles or so, then starts pulling to the right. What I have done is: replace rotors, calipers, bearings, left hose. Rear brakes appear to be working and the linings are good. I did not flush the system when I bled the fronts. When I take the hoses loose from the calipers, fluid doesn't run out of the hose, but will do so when manual bleeding. Also, I can disconnect both lines at the M/C and fluid does not run out. Do I have a bad master cylinder? Thanks, Mike
