Whenever I hear any oil has a milky color I believe it is a result of water getting into the oil. You should drain and replace the differential fluid because the water will wreak havok on the internal components.
You should definatly change the fluid, you have water contamination. You should also check the transfer case, transmission and rear diff for water contamination. Then extend the breather line on the fron diff.
