jkkrau
- October 3, 2008
- Valparaiso In.
- 2000 premier
I have a 2000 Mountaneer 5.0l and AWD with 160 K. Two years ago the front drive shaft went out, made a hell of a racket. Problem is I was 500 miles from home in the Apostle Islands on vacation. Ex Ford Mechanic removed it, through it in the back and said get it fixed when you get home, its a tough transmission you'll have nothing to worry about. I have replaced the whell bearing on the passenger side twice, and just recently replaced drive shaft again, due to a torn rubber boot which allowed all the grease to fly out. After installing the shaft and driving two weeks a growling noise has stared under the front end. I replaced the passenger bearing hub for the third time, still noise. It starts at approx 15 mph, at 20 gets louder and faster, by 60 its hummin pretty loud.If I make a sharp right hand turn it momentarily quites down, but then comes back to its previous level within a second or two. The front differential has signs of oil leaks at both output shafts and the input from the front driveshaft. I have added oil twice but not more than a half aquart. Both cv's are two years old from the last trouble shooting escapade. What should I do to troble shoot problem. How do I determin Transfer case, front differential etc.
