Front end cambered on both sides | Ford Explorer Forums
nismotunedgtr
Windham, Maine
'93 XLT 250k miles
HEy huy's, my front end seem's to have too much negative camber on both side's.
Both tires are worn on the inside's too. I don't care about the tires because I just got some BFG 31x10.5x15's....
Could it be the srpings are sagging up front? I don't want to put the BFG's on it until the fron end is good.
The truck also drifts to the right alot....
1993 XLT 4x4 228k miles.
the low camber is causing your truck to pull right and your toe is out also helping cause that tire wear... do a bushing alignment on it to help fix it, sagging springs shouldnt cause that much problems
just go get your alignment done. Your toe is probably out causing your tires to ware. If the camber was that ad you could see it from the front of your truck. The camber is easy to fix like he said with the bushing on the upper ball joint. But you should get an alignment unless you know how to do it yourself. The only problem with you trying to change the camber yourself is it will through off your caster and make your truck pull more.:eek:
