simso
- January 22, 2006
- Australia
- 98 XLT
Hi folks,
Did a search first to check if there was an easy answer but had no luck, I have a front end clunk when you change gears start of or reverese or even when you let the acclerator of and then put it on again it clunks. Exactly like a stuffed uni-joint "had them before". I jumped underneath and unis are good transmission mounts are good etc, but the front drive shaft can move an inch of rotation as I turn it back and forth I can hear the clunk and see the input shaft of the diff turn as well, so this means the slop and movement is in the diff itself, does anyone know how much movement should be available on the input shaft of the diff
Steve
Steve
