phantaztix
- August 18, 2007
- Escondido, CA
- '97 XLT AWD V8
So, I've replaced the front CV axles because I thought that was the issue, and they were clicking anyway.
But here's what's happening:
When I apply more than grandma speed idle power from a stop, it starts bangin (like a gear slip). It also does it during the shift from 1st to 2nd. It will also do it when I apply power when already moving. Bang, bang, bang, bang.
It feels/sounds like it's coming from the front left, but that's just as I hear it. But it's loud enough to be heard 200 feet away.
I replaced the CV axles like I said, and when doing so, the only issue I encountered was the right AXLE came out of the diff with the CV axle. But I got it unclipped and it slid right back in. A little diff fluid dripped out when the axle came out, and I took that as a good sign that there is fluid.
When I took the left side out, I looked into the diff as best I could, and I should have taken a picture, but I saw the gear shaft that the CV axle goes into, and then a vertical gear looking thing. I assumed it was the ring/pinion gear I was looking at but thought it looked weird.
While the CV's were out I checked the wheel bearings and they all are perfect.
Got the new CV's installed and properly torqued and it didn't change a thing.
So... Is it the diff that is blown? And I just didn't see the damage? Or could it be a blown wheel bearing?
It drives fine if coasting or decelerating in a turn or not. No grinding or clunking.
My next step is to pull the front driveshaft and see what happens. I don't mind being 2WD for now, but I also don't want to totally destroy the front end if it's a bad diff.
Any ideas? Clues? Comments?
