mikeh
- August 2, 2001
- St. Louis, MO
- 98 XLT SOHC V6
Before you ask I have searched on this subject and haven't been able to identify the problem.
I have a clunk coming from the front. It sounds like it is on the drivers side. Whenever I hit small or large bumps in the road going under 30 mph I hear this rather pronounced clunk from the front of my truck.
So I jack up the front of the car and proceed to shake everything. Nothing loose at all on the vertical ruling out upper and lower balljoints.
Shocks are tight and bolted with no play at all in them.
Torsion bar unmovable. Very tight in there.
No perceptable play in the hub.
Caliper is properly torqued in place.
Tie rod has no play at all.
I shook both sides of the front a bunch and couldn't come up with anything.
The only play I found was that the wheel would move about a 1/4-1/2" on the horizontal. This was just due to the steering mechanizm moving when I shook the wheel. The Tie rod and the Hub were not moving independently at all.
Also when I jacked up the truck I heard a very loud "Snap" or "boing" sound. I never identified where this sound came from nor could I reproduce it.
Help Please. I've really researched this and can't figure it out. If you have an idea what it might be please also include a test that will identify the issue.
Thanks,
mikeh
Thanks,
mikeh
