Kirby N.
- February 6, 2001
- Colorado Springs, CO
- 1991 Ranger
My front end has been popping ever since I put the duff 3" lift on it. When I back up down hill with my wheels cranked to the right, as soon as I get on the brakes pop! It sounds like something is shifting. It also does it when I get on the brakes hard sometimes. I had radius arm drop brackets, and It made the noise, and I recently switched to Duff extended arms and it still pops. When I switched to the Duff arms I put in spacers and 4wheelparts did an alignment and wanted to do upper and lower ball joints on 1 side and bearings on 1 side- so they did- but it didn't help. Is it normal or is it a ball joint? How do you check a ball joint? My wheel bearings are tight- I check them every 5,000 miles. THANKS
