I replaced both of my unit bearings last year, one was roaring and obviously bad. Since I was there I did both.
Both were original with 200k miles on them. Both were very loose and required almost no effort to turn, with one having a notchy feel to it and a rough noise, obviously bad.
I was surprised how tight the replacement bearings were. Both were NAPA Premium bearings, both had significantly more resistance to them - I. e. will turn smoothly but not spin freely on their own once released.
Frankly if either unit bearing spins freely if you "flick" it I would consider it worn out.
I have worn out TOYO ATs on mine, will replace this fall. I've always hated these tires. Even after the new bearings they transmit a large amount of road noise through the front end. Smooth road, silence. Rougher surface, roar.
I do have a full front end bushing job to do this summer, which may help, but no tires should transmit that much road noise on their own.
