front end squeals | Ford Explorer Forums
front end squeals
harveybobbie
1998 mercury mountaineer
the front end on my 1998 mountaineer awd squeals whenever the temperature drops below 60. my mech replaced the front end seals (spraying them with wd 40 had temporarialy stopped the squeak), but the squeal returned in less than 300 miles.
You are going to need to be a little more specific as there can be a few different squeals coming from the front of the vehicle. Is it a belt squeal, as in you start it up and before you do anything else the squeal is present? Does it squeal when you are turning? Does it squeal when going over bumps?
