Front End Vibration | Ford Explorer Forums
Front End Vibration
eltepo
Indianapolis, IN
"03 XLT AWD
I just started noticing a slight vibration on the front end of my '03 X XLT 4WD. It happens as I hit the 65 + miles, I can also feel the vibration on the steering wheel. Any ideas what could cause this?
i have the same problem shaking steering wheel between 65 to 80, smooths out past 80, also shake increases with turning, i dont have any humming, and i also got tires rebalanced. which makes me think that the bearings are good. also no play is noticble on the front wheels. but it still has a shake that isnt acceptable.
i had the same problem. it is the wheel bearings. close to 400 to replace
i have the same prob a vibration in the floorboard and when i make left turns the vibration stops and NOW i had grease on the pass front rim and down the side of truck SO i know which bearing is going to fail ...
Me too,, I have almost 50k on my 04... seems a bit soon for them to go.
