Front leveling kit | Ford Explorer Forums
Front leveling kit
Chevyy1212
Geneva, IL
2005 Explorer XLT
So I tried to I install my 1.5" leveling kit. Since I have to rotate the shock 180* for the holes to line up with the spacer on it just wouldn't work due to the lower shock bushing not facing rear and the shock coming in contact with a few spots.. Am I missing a step in the process here that makes it so the lower shock bushing can face rear with this spacer on? I attached a picture of the spacers but I'm pretty sure it's the same as 99% of them. Thanks in advance guys
You're going to need to spin the top cap around, you may need a spring compressor to relieve enough pressure to be able to do it...
Are you planning to install some on the rear too? Because the factory rake difference is only 1/4 inch...only need to raise the front 1/4" to "level" the vehicle...
Yea I kind of tried to spin them but nothing to much. And no I'm not doing the rear suspension I actually like the look of the front end a little higher. I'll look into spinning it tho that seems to be the best option
