front lug bolts | Ford Explorer Forums
front lug bolts
damnford
Location
pine city washington
94 explorer eddibouere
i bought a 91 explorer the other day and as i was checking things out i noticed three lug nuts missing and the treads were tfu after i got the tire off (easy with just two lug bolts) i noticed the slid in brake pad holders were missing as well. is it difficult to replace the lug bolts? i know to put them on i slip the bolt in and add some washers and tighten them up but are they easy to get out with the 4 wd? and wher should i buy them, i will replace all five and the lug nuts as well.
You can hammer out the old studs. This shows a 2wd, but it's the same procedure:
How To: Install wheel studs.
Definitely a good time to clean and repack the wheel bearings too.
Yep, best to use a big hammer!
