Team Chepsk8
- November 7, 2010
- Easton PA
- 2001 Explorer Sport Trak
Been working to isolate a troublesome leak. Last two Winters only (in the Northeast, sub-freezing outdoor temps). It will piddle about a half-cup of coolant when first started, and only the first cold start. A start later in the day it does not leak. Just replaced the water pump,bypass hose, and all clamps. No leaks on test drive, but leaked again the next cold morning. A few years back, replaced the plastic thermostat assembly. Truck runs on the thermostat temp, and does not overheat or run warm at any time, even Summer.
Looked at it this morning when it was dripping, seems to be on the passenger front/center side of motor.
So, I can rule out the water pump.
Can it be:
Head Gasket?
Intake Gasket?
Thermostat housing? (I HATE that stupid plastic assembly and ridiculous rubber-band O-rings)
Something else?
Should I pressure test it?
Should I try a cooling system sealer, and if so what type?
I appreciate any and all suggestions, and really want to hear about similar instances and the following solution.
The truck has 222,000,never a big problem,never had the motor apart, still runs smooth, no oil leaks, cannot discern if there is any extra steam in the exhaust, though I did check for bubbles in the radiator when hot and running, none. Motor is the 4.0 SOHV, truck is a 2001.
Thanks you in advance, this forum usually is able to come up with a viable solution!
Can it be:
Head Gasket?
Intake Gasket?
Something else?
