Front Pinion Seal Leak after replacement | Ford Explorer Forums
rc1626
Long Island, N.Y.
99 Explorer XLT
I just replaced my front pinion seal on my 99 Explorer 4WD as the old one was leaking. After replacement all looked good for about a day until it started leaking again. Replaced it a second time and it is still leaking. I don't think it is leaking when the truck sits but more so when the truck is moving and the gear oil is being sloshed around.
I was recently reading up on some threads on the board and some mentioned about setting bearing preload. I don't know if incorrect preload would cause a leak or not. It seems more like it would probably have more to do with premature bearing failure. So looking for feedback please. Any ideas on why I may be experiencing this reoccurring pinion seal leak? And how does one set bearing preload?
Any and all help appreciated.
Thanks.
Rob
does the yolk / flange have a worn in grove from the old pinion seal ring?
might need a new yolk/flange.
Thank you for the replies. I will certainly check the yolk flange the next time it is apart. Where is the vent tube if I might ask?
Thank you again.
Rob
On the top of the diff in a spot you can't reach unless your magic.
