mynameisaric
- January 18, 2004
- Location
- Illinois
- Bolingbrook, IL
- 98 XLT
- Callsign
- KD9OWX
so, my rear locker threw fits because my installer shaved the pin to get it past the 4.56 gears. i slid a whole pin in, and its been better, not perfect, but a great improvement. And the front locker has never done anything out of the ordinary, it has always been a good little locker. until about 2 weeks ago.
the little POS will not disengage. i pulled the front driveshaft to no avail. so the next day(yesterday) i pulled the front diff (and pulled out 2 broken CV shafts). cracked the diff cover off and looked inside and...... saw nothing out of the ordinary. except that the teeth on the powertrax were clamped shut. i put a flathead in there and that was the only way i could get the teeth to disengage. my pops tells me to replace the cv shafts(liftetime autozone warranty) and maybe it will work. so i put it all back together. put fluid back in and back out of my driveway. to my surprise, its disengaged and i can steer. i get to the end of my street and pull onto a main road "click click click" but i can still steer easily. next turn "click pop". next turn "pop pop clunk" and it engaged and still to this point remains engaged. pretty sure i have not snapped the new cv shafts yet, but i probably will sometime over the weekend at this rate. (there is still no driveshaft hooked up)
called richmond gear tech support... --->"i have no idea"
so my options:
A.) pull the front diff, cut the cv shafts, and turn into a 2wd and miss the badlands 10th anniversary.
B.) drive around till it explodes, and then think about option A
C.) someone chimes in and gives me easy instructions to fix this and i live happily ever after since my dad got ahold of a trailer to tow my little black POS explorer down to the badlands where i can beat the hell out of it and give it good reasons to snap cv shafts.
p.s. i thought about removing the locker, but since it is in the front diff i'm worried about shims n such and i have no idea how to setup gears or anything, and since i didnt do any of the installing on the diff i really have no clue where to start.
thanks for your help in advance. i love this forum community.
so my options:
