Front Right Wheel Bearings - Help | Page 2 | Ford Explorer Forums
Soory I took so long. I was away from a computer.
You put one on the Banjo bolt, put the hose on then put the other one on.
Basically sandwich the Brake hose between the two brass washers.
Make sure the old washer isn't stuck to the brake line. hard to tell sometimes.
OK... The caliper and pads are replaced and the rotors were still in tolerance with no pitting or grooves. I bled the system at all four points, but I am still getting some "cycling" when I step on the brakes... you know, a kind of vibration that slows as I slow down. It is no where NEAR what it was like before I replaced the calipers.
Thanks, in advance, for any tips.
Scott
