Front shock mount | Ford Explorer Forums
Front shock mount
KDA
Seattle, Wa.
'93 xlt
So what to do when The lower front shock mount shears off. The bolt connected to the radius arm sheared where the threads begin. Having taken a good look at the mount I see no obvious way of replacing it. It looks pressed in some way. What should I do? Replace the whole radius arm.
Same thing happen to me. Search for my posts on it.
Mine had been drilled out and replaced with a bolt before I got it. I later had that bolt welded in place and it works fine.
Could you give me a little more of a hint. I went through about 80 of your 109 pages of posts and did not recognize anything to do with subject at hand
