Front spindle removal on a 1993 Aerostar with RWD. | Ford Explorer Forums
alanbrucehall
indiana
1993 aerostar
how do you remove the driver side front spindle on a 1993 aerostar 2wd?:)
Welcome to this forum! I've renamed your thread, and moved it into the Aerostar section. The spindle is connected with 2 ball joints. The upper ball joint is connected to an upper control arm. The lower ball joint is pressed into a lower control arm. There are two bolts pressing these together on the spindle. Remove these bolts, drop the lower control arm, pull it out from the upper ball joint, then pull it out from the lower ball joint. Why do you want to remove the spindle? Make sure that you disconnect, and support the caliper. Don't let it hang from the brake hose.
