Front swaybar brackets | Ford Explorer Forums
wrightyonline
wolverhampton
1997 explorer 4.0 auto
Hi all, I have a problem locating these in the uk, anyone know where I can get them, the bar is the 36mm diameter one on a 97 truck , have tried rock auto but couldn't find them listed, got new poly bushes but need the brackets to hold it all together as originals were rotten !
Have you tried Energy Suspension or LMC Truck?
If your talking about the U shaped brackets, I would try an auto salvage yard if one is available near you.
If not, Pedstang is a vendor here, that most likely has a set he can ship you.
If you can find other vehicles with 36mm diameter bar and the same mounting bolt spacing, the brackets for that will probably work too. As far as that goes since you already have the bushings, with a bit of measurement you might be able to get a blacksmith to make them, especially if at least one of your originals is mostly intact besides being rusted... but I'd still do as gmanpaint suggested and check salvage yards.
