Front wheel noise? | Ford Explorer Forums
Front wheel noise?
cpumatt
Michigan
2001 Ford Explorer Sport
This morning I hop into my explorer and notice a noise coming from (I think) the front left wheel. It almost sounds like the tire is rubbing up against something (I have good clearance though), or it makes a noise as if one part of the tire is sticking to the black top and then coming unstuck. Like a *stick* *stick* *stick* noise. It is proportional to speed. Any thoughts?
EDIT: My tires are in very good condition, I recently got an alignment, and the pressure is up to par.
Just off the cuff... sounds like left front CV axle going bad to me.
Probably what chefduane said, or a rock stuck in the tread.
Went to Belle Tire and they were too busy to check. It seems to have died down in sound though. How much would a CV axle be to replace? Would a guy with a socket set be able to do it himself?
I would have a look at the wheel bearings also. They can tick also.
CV axles can be had for $80-$100 depending upon manufacturer. You might be able to find a L&R set for $150 or so. I know 1AAuto sells sets as does RA.
You might need a few other tools than just a socket set since as long as your tearing stuff apart you might want to do the hubs while you're at it. That would require a 32mm deep socket (IIRC) and a torque wrench for the hub nut. It also depends upon your level of confidence and expertise. Utoob is a good resource for video walkthrough's and this site is an invaluable tool for info. Just do a search for CV Axle repair/replace. Hey, I am a chef and have done a lot of stuff including hubs, CV's, inner/outer tie rods, brakes, shocks, etc, all from the stuff I learned here!
PS: Michigan, eh? UP'er or troll?
^ Downriver area if you know the area! Southeastern
I fixed the problem. It turned out to be some rusted off giant piece of what looked like a backing to something lodged up in there. I found it when I was checking my CV axle for rips in the rubber!
Probably the backing plate to the brake rotor. AKA dust shield. Glad it turned out to be something simple, but I would replace it fairly soon. JY item I suspect or maybe you could find one at a parts house.
