fuel filter replacement | Ford Explorer Forums
chuxdad
So. Cal.
2001 XLT 4X4
Anyone have any input on changing the fuel filter on an '01 Explorer? What's the best and easiest way to swap one out? Thanks in advance.
Run a search for fuel filter and you'll find threads describing the process. Best I can tell you is you need a special tool to remove the filter, and also should release pressure via schrader? valve before removal.
