stroked383z
- May 22, 2007
- Lebanon, VA
- 1999 Explorer Sport XLT
I recently acquired a 1999 Sport with the 4.0 SOHC. I am having a couple issues. First the fuel gauge isn't working and sits on empty all the time. When coming to a stop you can hear something clanging around in the fuel tank. I assume that its the fuel sending unit or something has fell off. Second my factory trailer wiring harness isnt working properly and i used my ohm meter and the only thing not working is the right hand turn signal. i checked it straight from the factory wiring. i tapped into the wires directly and the green isn't getting any volts or amps??? where does this wire end up going, and can i just splice the right hand wiring into the brake and the yellow turn signals from the vehicle lights. i hope i didn't confuse. thats the best way i know to explain it
