WV Hillbilly
- June 27, 2010
- Pennsboro , WV
1985 Ranger , 2.8 V6 , mechanical fuel pump so pump isn't in tank . Two wires connected to tank . Fuel gauge stays on empty all the time . How to troubleshoot before disassembling anything . Thanks in advance .
Update - I found the wire that goes from the sending unit in the tank to the fuel gauge was broken in the harness that runs toward the front of the truck . Break was about under the drivers door . Repaired break & gauge now works . I used an ohm meter & started at the tank & followed the wire until I didn't get a reading to isolate the break . Had to skin a little insulation off the wire as I went . Taped all skinned places after I found the break .
