James H. Lynn
- June 20, 2004
- Crosby, Texas
- 97 XLT
I have a 97-Explorer-5.0L. I replaced the #6 injector 3 times. I still receive the P0306 code on my scan tool. I have check all electrical aspects-short finder, ohm test, volt test, continuity check, replaced intake and upper intake gaskets, checked plug wires, vacuum leaks and still everthing checks out per specifications. I cleared all codes several times and after about 20 minutes warm-up time, the light comes back on. I checked for a possible broken wire and still I keep getting the P0306 code. I changed the #7 injector with #6 and vise versa-still no change.
If you have any information reguarding this problem would be very deeply appreceiated.
Thank You,
Jim Lynn
Thank You,
Jim Lynn
