fuel injectors | Ford Explorer Forums
fuel injectors
pearldrummer13
Elk Grove, CA
'91 EB
ok so my car has been stalling lately when it is cold, ive done many things and did a compression test and it passed. I got the fuel injectors flush and it ran well for a few days, but then it started doing it again. My friends dad says it sounds like the fuel injectors by he isnt positive. so is there a way to tell if it is the injectors or what should i do? Thanks a lot.
Run the Chevron fuel injector cleaner additive every second or third tank-full for a while. My '96 was doing this mainly when it had been off for about 30-60 min. After about 5 treatmants, the problem seems mostly gone.
i did that, it helps for about a week each time then it goes back. I did it probably 4 times.
is that solves it then i recomend taking them out and pressure cleaning them with solvent
when was the fuel filter last changed
i changed the fule filter about a week ago. when i had the fuel injectors flushed would they have told me if my fuel injectors are bad or would they not know?
