rtaylor0
- April 29, 2017
- Wyoming
- 1997 Ford Explorer XLT
Hello Everyone,
So, I recently purchased a 1997 Ford Explorer XLT 4x4 (4.0L SOHC). Anyways, I'll give you a little background here. I bought the vehicle and shortly after I got check engine lights for P0171 and P0174 (Which means it's running lean). My first impression was to change the fuel filter so I did. I then learned that the PCV elbow can sometimes be bad so I checked that and it was fine. I took it to a mechanic who replaced the intake manifold gaskets but it still has the same problem. I tried replacing the upstream oxygen sensors but that didn't fix the problem either. Following that I tried cleaning the MAF sensor, still with same problem.
So, anyways to get the vehicle to start I have to prime it a couple times otherwise it cranks for a long time. So, I got a fuel pressure test kit to test the fuel pressure. When the vehicle was running it ran at a constant 30psi but when I turned off the vehicle it slowly dropped off to 0psi. So, I figured this must be my problem. But, I'm not sure where to take it from here. Any advice would be greatly appreciated!
