cargarci42
- October 5, 2012
- Puerto Rico
- 2001 Ford Explorer 4.0
Hi all!
I am new to the forum and appreciate very much any help!
I have a 2001 Ford explorer 4.0 SOHC with the returnless fuel system.
My problem is that the vehicle is;
1. hard to start (takes about 3 to 4 times cranking to start the truck
2. Vehicle hesitates when pressing gas pedal
3. when coming to a stop sometimes revolutions drop to about 500 and jump back again to normal
I changed the fuel filter and no luck. I put a fuel pressure gauge and noticed that with the key in the ignition I have zero pressure. After cranking 3 times the truck starts and then I have 62 psi and stays there until I shut down the truck.
As soon as I shut down the truck the 62psi goes immediately to 0psi.
What can I check or what is suspected here?
I have read some threads and I am trying to avoid droping the fuel tank???
