rickpotz
- September 19, 2008
- Utah
- 2000 Sport
Okay guys or gals, your diagnosis of what I'm about to describe is going to be fuel pump or fuel filter! I already know that.
What I don't know is why? I've had to change three fuel pumps in the less than 10,000 miles and now I'm about to do it again!
I have a fuel pressure reading at times of over 60 psi. If i just let the car run for a few minutes that 60 goes as low as 30 or 10 psi.
Oh, you should know that this is a 2000 explorer with about 87,000 miles on it. I just replaced this part about 3 months ago with a Ford fuel filter.
Sometimes when I start the car I can drive it for days other times the pressure drops. Often I can restart it and the problem goes away. Sometimes it won't.
What is frustrating is the number of times I have diagnosed the same problem yet after pump replacement the car runs fine for a few months and then the pump goes out again. The symptoms may change but the end result is the same: fuel pump replacement.
The fuel filter seemed good but I replaced it anyway.
I did have two codes but I didn't pay much attention to them due to the fuel pump readings. I think the codes were 174 and either 170 or 171.
I used a vacuum gauge on the pressure regulator value and gave it about 10 lbs of pressure- the diaphram holds! I'm not sure how much pressure it needs hold? My experience is that if the diaphram is bad it will lose pressure regardless. No signs of fuel in the vacuum hose either.
I'm not sure the pressure regulator value could boost the fuel pressure that much anyway.
Everything leads back to a bad fuel filter the question is why? What is making my fuel filters go bad? Like I said this is the fourth time.
I would appreciate some imput from some savy ford mechanics.
Tears-- I mean cheers!
