fuel pump relay... parts # needed | Ford Explorer Forums
Status
Not open for further replies.
93liftedXLT
left coast
92 xlt
i need the parts number for a :
fuel pump relay ,for a 92 ford explorer
thanks
There are three relays in there. If you buy them from Ford, they are three different colors and have a Keying bump on them so you can't make a mistake. IF you buy aftermarket, it is all the same relay, they make the housing to straddle over the Keying mechanism.
Sorry I can't help you with the number but any autostore can get you the generic Relay. $16 ish
Let me see if I can get it. and write back
NAPA# AR240 for fuel pump relay.
do you know were to install it...lol
its on the underside of the engine fuse box.
yeah, i am having a hell of a time, getting the fuse box out...
Is there something im missing? special trip? working on it as we spech
need help
thanks
There is a metal bracket between the Fuse block and fender. take a long bladed screwdriver and slightly pry it. The Fuse block is clipped into it. Look at it with a Flashlight you will see how the Fuse block snaps into it. You will have to do some wiggling.
Status
