jimbolin
- April 7, 2005
- crosby,texas
- 93 4 door
I thought I had this problem fixed until this morning.Turn the key on and lo and behold the fuel pump goes past prime mode and continues to run.I turn ignition on and off a few times,fuel pump primes like it is supposed to and then starts to run like crap and cel comes on and then all of a sudden it goes off and runs fine.As I let it idle it all of a sudden revs up with the throttle not being actuated.I then pulled relay and it settles down.It kept on repeating this scenario.I have swapped relays out a couple of times now with no positive results.I have pulled codes and I get a 123 and 125 both related to TPS.The second time I pulled codes with the comp. going through it's process the pump would not shut off allowing the test to continue.I am at wits end now,where do I go from here?
