Mtn_Man
- June 21, 2005
- NC
- 1994 Limited 4WD
Chek me on this: 94 Limited
1. The inertia switch is set (red button down)
2. I yanked the relay to the Fuel Pump and shorted the two connections to activate the fuel pump (not the field leads, the normally open connection)
Got a big nada. No sound, nothing. Truck has sat (with fuel in the tank) for about 4 years. I just rebuilt the motor and siphoned out the gas and was going to use the pump to finish the job as the filter is out right now. Shouldn't the pump just run once I short the relay leads? Is there a low fuel cut out switch or something like that? Is it just shellaced up? New battery so there is voltage. Is there something in the anti-theft that's blocking me here? The hood is off so I could get the motor in. I read that the hood switch needed to be cycled before the anti-theft could be activated if the system was brought up with the hood open. I realy don't want to drop the tank, but it won't be anything new. This rebuild has done nothing but nickle and dime me to death anyway. Ideas?
