mystic184
- April 5, 2004
- MI
- 02 XLS
I have an 02 Explorer that has had intermittent starting problems. I have suspected a fuel pressure problem so I hooked up a gauge and tested it. When I turn the key on it jumps to 40-50psi then back to zero. When starting, it pressurizes again and once started it maintains 65-70psi. Am I correct in assuming that the fuel system should remain pressurized while the key is on before cranking? I have checked and there are no fuel leaks anywhere that I can tell. Is there a check valve in the fuel pump (or anywhere in the system) that could be bad? I'm just trying to narrow down potential problems.
Any help is appreciated.
