drdoug
- August 23, 2011
- Grand Rapids, MI
- 1995 XLT. Stock.
Good morning,
I cant find the IAC thread so I am posting here.
I replaced my IAC on the 95 XLT. The felt filters were brittle and powdery. It appeared charred on the inside as well. Very dirty. It was an easy replacement for sure just had to make sure I had the right connector.
As soon as I started her up the RPM shot up to 2000. I let it stay that way for 30 seconds and shut it off because I wasnt sure that was supposed to happen but because of the new valve I thought maybe it had to reprogram.
I started it up and let it idle high for a minute and it started to climb down slowly. I drove around the block and it seemed ok. Awhile later I started it up and the idle was very rough dropping below 1000 to 500 or so. It did that this AM as well.
I drove it to the office this AM and it seems fine now although idle RPM is at 1200 for the most part. Previously it was 9-1000.
Does any one know.....Should the warning light on the dash go off by itself after the fix ?
BTW one shop that start with N wanted 140 bucks and AZ wanted 79 bucks. Don't wanna bash cos I use them both not sure if it is against etiquette to name names either..... but they are literally across the street from each other. 2x price.
thanks,
Doug
thanks,
Doug
