Fuses?! | Ford Explorer Forums
Fuses?!
Exploder6720
Mishawaka
2011 Explorer XLT 4WD
Callsign
BigBird
So I have an issue with the 12V outlets in B.B. my 2011 Explorer. The one in my center console doesn't work, the one behind center compartment between the front seats for the middle row doesn't work but the one inside the center compartment between the front seats works and the one in the trunk for the third row works. I don't know which fuses goes to which one or if even it's the fuses that are the problem. Had any one heard of that combination of 12v outlets working n not working before? Anyway any ideas on what to look for and check and/or know how to fix this issue.
Welcome to the Forum. :wave:
The fuses for the power points are all listed in the Owner's Manual. That would be the place to start before considering anything else.
Thanks I actually figured it out. I knew where the fuses were but the new fuses my boyfriend out in were the wrong ones he put 40a in them when they only took 30. So just me being curiouse I put in the right ones n they work fine now.
A larger fuse won’t keep them from working. Might cause a fire, but a 40A fuse will function exactly as a 30A. The 40s must have already been burned.
