Gas Mileage | Page 2 | Ford Explorer Forums
Gas Mileage
For what it's worth.
I usually check my Gas mileage everytime I fill up.
after one wheel'n trip (my last where I got stuck BAD twice) I got 17.9. For some reason I checked my tire pressure and it was at 45-50 :eek: :confused: My last oil change must have filled them up to the max. So I lowered it back to 32 all around. I also took a close look at my tires to find the centers bald. I looked at them the other day and also noticed the pass side inside edge is bald. ARRGH!
As far as Gas mileage I've only seen 17 onces since then. I drive 20-30 miles to work 5 days a week (all highway) and Once a week drive 120 miles round trip. I set my cruise and usually go 65 (If I'm not late) and 72 (If I'm behind schedule)
I have synthetic oil, 3:73 LS, smaller stock tires.
What gives?!? I must have calculated something wrong on the wheel'n trip. I was a 2.5 - 3 hr drive to get there, but still!!!! Maybe my truck likes the dirt!!! Hee hee hee!!:D
Thanks Alec, I will talk to a friend I have in the tire
business and see what his recommendation is..
Sid
Originally posted by Alec
Be aware that running most tires at 38-40 psi on the street will make your ride much harsher, worsen handling and traction, and cause uneven and crappy tire wear.
Where you buy your gas has something to do with the gas milage. If you buy gas in a ozone non-atainment area, usually a large metropolitian area, you are buying reformulated gasoline (RFG). Typically, gas milage is reduced by 10 to 15% when using a RFG. You can be sure you are buying RFG if the pumps have vapor recovery systems on the nozzle. FRG is also about $0.10 a gallon more than regular gas.
Just a thought about tire size
It is possible, when running aftermarket tires not of original size, that the speedo/odo won't be calculated correctly right? Is it possible to go the the dealer and have them use the NGS tool to change tire diameter?
Mike
I get about 17 mpg mix city and highway driving. In the city, I only get around 12 mpg and the highest I can get on the highway is 21 and it only happened twice. I think I'll get a lower number for this tank b/c of my new mod with the throttle cable. :D Thanks guys!!!
Well I havent owned my truck long enough to give a dead-on MPG rating. However I will tell you that I drove from Philly, to Woodbridge, VA(South of DC) on half-a-tank. Thats about 200miles. Im guessing that I would have gotten another 100-150 miles out of the tank. Not too shabby.
RE: Fhantazm
Don't trust the gas gauge. If there is one thing i hate about fords its that it goes from full to half really slow, then speeds up dramatically. i am reading 160 on this tank and half left, but i know the only way i can get another 150 is if it is all highway and i will be running on fumers at trip end. the most i have ever gotten on a tank (in either of our exs) was 305 and that was 70mph the entire way.
