Gas smell inside the cabin. | Ford Explorer Forums
Explorer_PL
Rockland County, NY
06EB V8
2006 v8, 301k miles
150k miles on the current engine
For the past few months, I can smell the gas or very rich exhaust fumes inside the cabin, especially at start.
I looked under the hood, checked injectors for any leaks and nothing.
The long term fuel trim is 8-9 % on both banks, short term is -2%
The exhaust smokes a little, I am still not sure if those are valve seals or piston rings.
No error codes or misfires whatsoever, runs strong and smooth.
I thought EVAP leak somewhere or canister is bad, but again, no codes.
The whole exhaust system was replaced including manifolds, and I checked with my bare hands for leaks at the joints but all is good.
Fuel system and EVAP system still original from the factory.
Any ideas ?
Thanks
Gas pump seal gone maybe?
96 had a rotted out evap line. Replaced with a 20' 7/16 fuel hose from a parts store. There was a hole in the tube under the hood and a few others on the tube. You should get some codes though with that problem. Bad gas smell.
Smoke test the evap system...
96 - I am thinking about getting a cheap smoke machine. But again, no EVAP errors .....
Bazz - the fuel pump seal - you mean the ring on top of the tank under the pump ?
Yes
But if you have no EVAP codes theoretically you have no leaks in your fuel system...
