CBKBAMF
- June 27, 2009
- Tacoma, WA
- 1995 XLT
Seems to be a real issue with these trucks.
Anyhow, symptoms are as follows:
Intermittently over the last month the truck would turn over but fail to start. after letting it sit for a bit, it would fire right up and run/drive like normal. The frequency of this occurring has become more and more frequent up until the other day when it did this and it hasn't started since.
KOEO: Check Gauges light comes on, upon cranking light goes off (ruling out Crank Angle Sensor). Fuel pump primes (can hear it when turning key to "on" position ruling out fuel pump). Removed plug, grounded it, turned key over and gets good spark (rules out coil pack). Engine turns over with no discernible changes from when it normally starts, however engine doesn't fire and run. Just continuously turns over.
What I've done:
Replaced the idle air control module (it was the AA varient, $170 at Napa! OMG!!), as it was surging at idle, problem continues. Brand new battery approx 1 month ago.
I can't figure out if there is a cam angle sensor or not on this engine (searching the forums returns a lot of different results, including a part that isn't manufactured anymore and is a common culprit).
I'd like to test the injectors to see if they are firing (as the plug I pulled out seemed pretty dry), but I can't find a how-to on this forum on how to do it.
There is no "anti-theft" on this truck either, as far as I can tell. There is no light on the dash designating any type of anti-theft features.
Help or direction, please!
1995 Ford Explorer XLT 4WD 4 door 4L V6 w/EFI.
What I've done:
