If you look under the back of your X there may also be a metal tag that is on one of the bolts on the transfer case cover. It should be labeled on there what the gears are.
just check the sticker on the drivers side door.... Then type in Gear Codes in this forums search area and tons of stuff should pop due to other people also wanting to know
