Gear ratios - trac loc vs non trac loc. | Ford Explorer Forums
ksanders
Tulsa, Okay
Do the trac lok and non trac lok rear ends share the same range of gear ratios or do the trac lok rear ends only have a select list of gear ratios?
If you are going to put a trac lock in a non trac lock, in many cases you can use the same gears.
