Gear selector problem. | Ford Explorer Forums
truckNserious
Bremerton Washington
2wd v6 EddieBauer edt.
I have a 1991 ford explorer 2wd v6 eddie bauer edt. I was wondering if I put it in park to put the shifter cabel back on the gear selector or do I do it in a different gear?
Welcome to the site.If you post this in tech,someone will reply I'm sure.
The needle should be adjusted with the selector in the OD range. Adjust the needle by removing the steering column shroud and loosening the set screw on the column. Put the needle on the OD mark by sliding the white plastic cable sheath and tighten the screw. That should do it for you. Its pretty easy once you look at it.
