All it says on the inside of the door for axle is D4?? Does anyone know how 4:10 gears are on the highway?? Whats the top speed?? Do you also have to change the front axle gears too???
Yes, if you have 4x4 (and still want to use it) you need to change the gears in both differentials. 3.73s are a good middle-ground gear for stock tires. No use going to 4.10s, not enough difference for the money.
