Gears | Ford Explorer Forums
Gears
ledgebutta
milford, CT
91 XLT
i was wondering which gears come in the 91 XLT 5 Speed Tranny......and which
size i should switch to when i get 33's
What do you have now? If you have 4.10's then you'd probably be ok. I'd think about gearing lower though if you don't have 4.10's, maybe 4.56's....Many threads about this, do a search and you'll find alot of info :D
Okay ill look around on here to see if i can find anything...im pretty sure it has 4.10s in there now...thanks for the help
check the code on the inside of the drivers door, give us the big letter/number combo and someone on here can tell you what it is. The gear ratios differed in models.
okay cool ill just look on the door to see if its there
