00REDEXPXLT
- March 10, 2007
- the "SKILL", NY
- 2000 EXP XLT
I just swapped in an electric 1354 tcase from a 98 ranger. everything bolted up fine and the selector motor from the 4405 bolted right on and has the same range of movement as the one from the 1354. Now the only problem is getting the dash selector to work. It seems the dash selector is run through the GEM behind the radio. The shift pattern on the 4405 is H-neutral-L in that order. The pattern on the 1354 is 2H-4H-4L in that order. The question is can i swap in a GEM from say a 2000 ranger with electric shift 4X and power windows? I can get the selector motor to turn its full range from 2H to 4L but how do i get it to select or stop at 4H in the middle?
thanx dave
thanx dave
