Gen 3 Speedo Gear help | Ford Explorer Forums
red97XJ
IN
97 XJ
Hey guys, on a Gen 3 is there a different speedo gear that can be put on at the transmission? Bigger tires are making the speedo off and I want a way to correct it cheaply. If so, is there a chart somewhere that tells me what I need to order from FMS?
Thanks,
Jason
anyway to adjust the computer to read correct speed and mileage?
Thanks,
Jason
If its less than 10% off, you can have Ford reprogram the computer. Or you can get a chip that adjusts for the new tires. Or you can install a Superlift Tru-Speed, and adjust it yourself.
It is still under warranty, do you think Ford will adjust for free or will they charge? If they charge, how much should it be?
How much is a super lift tru speed?
Thanks guys,
Jason
