G
Great White
Have new wires, new plugs,new fuelfilter.cleaned iac,maf.
New upper and lower intake gaskets.(got god idel back
Still same problem with getting the engine to allow me to put my fot on the gas,just starts to blurr,jump and acting like it only fireing on a couple of cylinders. can take the wires of the pluggs on passengerside and still get the engine to start,but not the other way.
so it seems like the problem is on the passengerside.
Tryed to switch pluggs passengersid/driverside,still same side working.
tryed new ciolpack,no change.
put 02 sensor from driverside on passengerside , and after a coupel of times
turning on the key,i got it to start with only wires on passengerside conected.
at last i though....its the 02 sensor.
just wanted to make sure,so i tryed to start it again.....wouldent start
do you have to disconnect the battery when you have changed 02 sensors?
Realy dont want to bye a new 02 sensor if that's not the broblem.
Is FPR placed after or before injectors?
(you can feal the engine getting correct fireing for a second (ones and a while)......but something is holding it back.
